small turbo cam cover
is it possible to fit to big turbo cosworths?
im going coil pack so want to hide the leads
also does anyone do a alloy cambelt cover for the small turbo?
thanx
thanx
Yes, small turbo head was re-designed, so qiute a few differences at the top as well. Deffo not compatable with the earlier cam covers..........Also the coil packs "within the cam cover" is NOT a good idea IMO, as this is a very hot part of the engine, and the excessive heat is the main reason that these coil packs fail. Usually the first symptoms are a missfire on boost. Better to fit coil packs elsewhere within the engine bay.
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
be rude not to tell you wouldnt it
