T4 TURBO MARKINGS.......... UPDATED : NOW WITH PICS.....???
Old Nov 26, 2004 | 05:06 PM
Jim Green's Avatar
Jim Green
Default T4 TURBO MARKINGS.......... UPDATED : NOW WITH PICS.....???
Got my T4 off the car at the moment as it's always been very laggy (Compared to other T4's)
Can't find any markings which I would normally have expected to find (T04E I believe was the normal marking on an RS500 Turbo).
The only Markings I can find are " M10 A/R .70 GARRETT 367-2" In that order around the front of the turbo casting.
Any ideas......
Old Nov 26, 2004 | 05:48 PM
Jim Green's Avatar
Jim Green
Come On......
Somebody must know, or know somebody who does.......
It's probably of a Cummins Diesel !!!!!
Old Nov 26, 2004 | 06:01 PM
ImaRacing 700's Avatar
ImaRacing 700
Jim...when does that T4 spool up?????....The A/R is right.
My pukka one made full boost by 4300RPM.......
Old Nov 26, 2004 | 06:14 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Jim, T4s dont say T04E on them, thats just what they called.
What ex housing a/r is it?
Itd almost certainly be the right one as i dont think you can get bigger that fits with an internal gate, but dunno...
Old Nov 26, 2004 | 06:16 PM
Jim Green's Avatar
Jim Green
Spools up around 5.5k and then just keeps boosting.
Have identified that the exhaust turbine is not cut back, but it appears to have a different pitch to a normal RS500 T4.
Will sent pic of exhaust blades if it'll help.
Just don't seem to be able to find any T04E Markings on it though, so think it might not have originally come from and RS500
Old Nov 26, 2004 | 06:19 PM
justin.e's Avatar
justin.e
5.5k fooling hell Jim thats like watching paint dry!I'll go out to the shed and have a look
Old Nov 26, 2004 | 06:21 PM
Ian M's Avatar
Ian M
spooling up at 5.5k that must be hard work to drive
Jim Green's Avatar
Jim Green
I don't have a Photo Bucket account, but I've e-mailed Phil some pics, so maybe .... Phil can post them up for me......
Cheers Phil
Old Nov 26, 2004 | 06:25 PM
justin.e's Avatar
justin.e
ar 70 m24 on mine Jim
Old Nov 26, 2004 | 06:26 PM
Jim Green's Avatar
Jim Green
Yep, it's like waiting for paint to dry, but when it does come in it just keeps coming all the way to the red line.
Sending it to Vince at Universal Turbo's to have it diagnosed as I bought it as a rebuilt unit (Which it was) But don't know it's history or what it was built up for other than the seller stated it was built up for a big bhp cossie engine.
From the pics of the exhaust wheel, karl and Mike "R" recon it's not got a cut back wheel, but the pitch of the blades don't look like a RS500 should. The pitch is wrong.
Just trying to identify what it might of orignally come from (If it didn't come off an RS500, and what spec it might be.....
Old Nov 26, 2004 | 06:28 PM
Jim Green's Avatar
Jim Green
Mmm.
Justin... A/R . 70 on mine too, preceded by "M10" and after the "GARRETT" wording there is the markings 367-2
Old Nov 26, 2004 | 06:30 PM
Jim Green's Avatar
Jim Green
IAN : Yep, it is, hence it's now off the car and going to Vince at Universal Turbo's to be sorted.
Just imagining what he might say. Lol
Old Nov 26, 2004 | 06:32 PM
ImaRacing 700
No e-mail yet....and i now gotta go out.....send it to someone else mate..or i will post em up tommorrow if the mail arrives.
justin.e's Avatar
justin.e
definately M24 on mine I'll go back out and pull off the airbox hose
Old Nov 26, 2004 | 06:33 PM
Jim Green's Avatar
Jim Green
Anyone who can post the pics up if I send them to them by e-mail......
Phil : No problem matey, I'll see if someone else can post them up for me.
Jim
Old Nov 26, 2004 | 06:35 PM
Disabled Account's Avatar
Disabled Account
Jim,
My T4 is at full boost by 3,800 RPM. Supplied by Vince (purchased from Harvey SCS).....Perhaps ask Vince to re-core it as a "standard SCS spec" unit, i.e. SCS trim/360° bearing etc..........these are good for 540 - even 550 BHP
Old Nov 26, 2004 | 06:37 PM
justin.e's Avatar
justin.e
ok BCI A/R 70 M24 GARRETT thats all thats on the front of mine Jim
Old Nov 26, 2004 | 06:38 PM
Jim Green's Avatar
Jim Green
Thanks Doug...... Have been considering that, as I know he builds up Harveys.
On full boost at anything under 4k would suit me fine. I'm not into red lining it all the time. Karls doing my head for me, so hopefully it's all come together soon, but I need the turbo sorted first.
Old Nov 26, 2004 | 06:39 PM
martinrs500labatts's Avatar
martinrs500labatts
sounds a bit too laggy,
mine can on at 4.5 rpm atleast,
sounds like there is something a miss with the turbo spec,
perhaps take it off and borrow another T4,
i have a spare good one,
Old Nov 26, 2004 | 06:42 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
For it to be THAT laggy id say theres somthing wrong rather than it being the turbo.
No way would just cut back blades etc make the bloody thing be 1000rpm worse in lag.
Even the ex housing would have to be drasticly bigger to be that much worse, and i doubt if its any bigger at all.
Id put my money on another problem, a unnoticed boost leak (intercooler?), wastegate not sealing properly, or some issue with cam timing or summat, as 5500rpm is REALLY bad even for a T4...
Old Nov 26, 2004 | 06:45 PM
Ian M's Avatar
Ian M
the shaft is probably for a large wagon application or some such thing i know there was a few t4s knocking about that had been put together that way.
Old Nov 26, 2004 | 06:46 PM
Jim Green's Avatar
Jim Green
Yep, we (Karl and Me) thought that it might be something else, but as a stage 3 on greens and a T34 it made 327bhp and good torque, all we did was put in grey injectors and the T4 and it ended up as it is now, so don't think the problem is with the engine. The intercooler has been checked, and no leaks, wastegate appears not to be leaking, but will get vince to check it out.
Old Nov 26, 2004 | 06:50 PM
Jim Green's Avatar
Jim Green
Martin. : Thanks for the offer..... I'll see what Vince says first, and go from there.
Never know I might have to by another one, as I don't know what they can do with turbo's . I guess it could end up being a big rebuild bill for mine, or buy another one.
What I basically want, is a standard RS500 T4 or one modified to reduce the lag (As much as possible on a T4.
Old Nov 26, 2004 | 06:54 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Even if i was off one, the shaft being off a lorry wouldnt affect anything apart from strength.
Its the same housings (or youd of noticed), if it was off a diesel the exhaust housing would be far far bigger compared to the compressor (as diesels create far more ex gas than a 4stroke petrol so need bigger housings), so dont worry there.
Old Nov 26, 2004 | 07:00 PM
Jim Green's Avatar
Jim Green
Exhaust housing is A/R .65 (Just checked it)
Old Nov 26, 2004 | 07:01 PM
Jim Green's Avatar
Jim Green
Can anyone post some pics up if I e-mail them to you ????
Might help someone identify something...
Old Nov 26, 2004 | 07:19 PM
Ratty's Avatar
Ratty
Email em to me, I'll host em
Old Nov 26, 2004 | 07:45 PM
Jim Green's Avatar
Jim Green
Tks Ratty, What's your e-mail addy....
Old Nov 26, 2004 | 07:47 PM
Chris Honeywell's Avatar
Chris Honeywell
Exactly like mine!!!
Old Nov 26, 2004 | 07:48 PM
SPADGE's Avatar
SPADGE
Jim the exhaust housing should be a .63
Has your T4 had the penny wheel enlarged?
Send me the pics and i'll post them up for you but can you also send me a pic of your complete engine bay as well
Old Nov 26, 2004 | 07:53 PM
Disabled Account
Jim,
The markngs in my T4................only got these 2 pics:
Old Nov 26, 2004 | 07:58 PM
SPADGE's Avatar
SPADGE
Here is a pic of one of my old T4's Jim it has the same markings as Dougs!
Old Nov 26, 2004 | 08:08 PM
Ratty's Avatar
Ratty
Large pic warning
Jim's turbo
http://www.wiltshire-computing.co.uk...php?pic_id=135
http://www.wiltshire-computing.co.uk...php?pic_id=136
http://www.wiltshire-computing.co.uk...php?pic_id=137
Old Nov 26, 2004 | 08:33 PM
Jim Green's Avatar
Jim Green
SPADGE : That one has the same markings as mine......
Does it have the code "367-2" after the Garratt Markings ???
Old Nov 26, 2004 | 09:39 PM
SPADGE's Avatar
SPADGE
No idea sorry mate i sold that turbo months ago!
Old Nov 26, 2004 | 10:01 PM
Jim Green's Avatar
Jim Green
No Probs Spadge,
From what I can see on yours the markings are exactly the same as mine, so i feel a little more confident now.
Jim Green's Avatar
Jim Green
BTTT
Old Nov 26, 2004 | 10:02 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
put it back on the truck it was stole from and buy a modern turbo
Old Nov 26, 2004 | 10:06 PM
Jim Green's Avatar
Jim Green
Hi Gus,
On a shoe string budget at the moment, and if it was good enough for Labatts and Andy Rouse it's good enough for me.
Old Nov 26, 2004 | 10:08 PM
Rs Gus's Avatar
Rs Gus
Hi Gus,
they was not road cars jim was they NO your is YES hence why the t4 is wank i know ive lived with one aswell not again
