spare wheel well
Old Nov 26, 2004 | 02:44 PM
boost mad's Avatar
boost mad
Default spare wheel well
how easy and safe is it to remove the spare wheel well on a sierra, ( forgettign the fuel pump cut out thingy )
cheers
Old Nov 26, 2004 | 06:50 PM
xpackcapri's Avatar
xpackcapri
Old Nov 26, 2004 | 07:57 PM
Tony Ryan's Avatar
Tony Ryan
Have a look at my resto page , or come over and have a look at my car, ive done this to sink a Fuel cell under the rear floor for weight distribution purposes .
Old Nov 26, 2004 | 08:00 PM
Lee @ Fusion's Avatar
Lee @ Fusion
easy peasy mate , i charge £35 for this ,
Get a angle grinder with a 1mm cutting disc and cut the wheel well out just befor the radius where is dropps down ,
Get a sheet of steel , ( i use 1.2mm , but 0.9 is fine ) cut it into a circle about 10 mm bigger than the hole u just cut in the boot floor ,
Place on hole and tack into place , stitch weld arount the whole lot , inch at a time to disapate heat
I use Grey stripe pannel sealer on the under side of the car to seal it all away from the elements , and then primer , Obviously a lick of body colour would be the finishing touch .
jessie_rs
Jan 5, 2016 01:16 PM
jessie_rs
Sep 16, 2015 10:34 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
jessie_rs
Sep 7, 2015 01:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
