New Turbo time!
Old Nov 26, 2004 | 11:51 AM
Daveyboy's Avatar
Daveyboy
Default New Turbo time!
Im sure this has been done to death... for which i apologise However, im in a dilema as to what new turbo to get when the saph hits the road again.
Its curently running a T3 on a stage 1 chip. I am however going to go stage 3 before it comes back out again.
The car is a road car and will be used as such 90% of the time. Would you go for a T3 or a T34? I realise the T34 will be better suited for stage 3 and probably last longer, but i love the drive of my T3 as oppose to Waps or Colas slightly laggier T34.
For driveability on the roads, would a T3 not be better? i realise it will probably pop before a T34, but surely more fun?
what do you think? anyone running stage3 with a T3?
Old Nov 26, 2004 | 11:55 AM
mattbibs's Avatar
mattbibs
it your choice at the end of the day. if you like the drive of the T3 then keep it!
but think it was rhys that said just other day that he got bored without power at the top of the rev range! up to you and your driving styles really!
Old Nov 26, 2004 | 11:59 AM
rapidcossie's Avatar
rapidcossie
t34 all the way!
pulls much harder above 130
Old Nov 26, 2004 | 12:01 PM
SapphyMike's Avatar
SapphyMike
i went from a T3 to a T34 when i went for an NMS stage 1. All i can say is i am glad i did
Old Nov 26, 2004 | 12:30 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
t34.48
Old Nov 26, 2004 | 12:39 PM
Spiky's Avatar
Spiky
davey, get a t34 with .48, low lag then, with top eng pull
Old Nov 26, 2004 | 09:06 PM
Rhys's Avatar
Rhys
lol thought u wasnt converted to .63 Spiky!
GEt a T34 on there mate. but be warned u will soon be want more
Old Nov 26, 2004 | 09:16 PM
wimwerf's Avatar
wimwerf
i have recently a t-35.63 stage 3...im very glad with it. its a little bit more lag (500rpm) but then it gives much more grunt.
Old Nov 26, 2004 | 09:18 PM
Andreas's Avatar
Andreas
T34 0.48, not much laggier than the T3 but pulls better.
Old Nov 26, 2004 | 10:16 PM
phill2400's Avatar
phill2400
T 34 more pull at the top.
Old Nov 26, 2004 | 10:22 PM
R4N SS's Avatar
R4N SS
i had a t34 0.48 on my last engine which was stg3 and it pulled very well and was not laggy at all. The newer engine is a bit laggier but it is on a t34 .63 now but pulls so much stronger
Old Nov 26, 2004 | 11:20 PM
Alvyn's Avatar
Alvyn
m8 got a t34 with 48 housing and is infront of me by a wing(both on stage 3 set ups) up to the tonne then my 63 takes over so as Rans has said I think the 63 pulls alot stronger higher up the rev range. I don't really suffer from too much lag while driving the saf around
Old Nov 27, 2004 | 12:32 AM
Mr.worth's Avatar
Mr.worth
Nice sideways in your siggy phil'
davey boy id go for a t34 48 housing m8
Billy_RS
16
Oct 11, 2025 09:41 PM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Aug 16, 2015 07:14 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
