zvh bottom pulley/sensor for eng management??
Old Nov 26, 2004 | 07:48 AM
Paddy rst's Avatar
Paddy rst
Default zvh bottom pulley/sensor for eng management??
fitting cosworth management to my s1 over the winter...
just wondering how u zvh boys have mounted the crank sensor, and how the bottom pulley has been modded to work with cos management??
any info , pics would be helpfull just to get an idea whats involved..
cheers Paddy.
Old Nov 26, 2004 | 07:53 AM
zvhturbo's Avatar
zvhturbo
Thats the best way.
Use the crank sensor from a 2.0ltr Zetec in the correct carrier and use the EFI (Late XR3I, Fiesta RS etc) flywheel.
Matt.
Old Nov 26, 2004 | 08:08 AM
Bomber's Avatar
Bomber
zvhturbo - that wont help with Cosworth management which uses 4 pickup points - the EECIV flywheel has 32-1 (or 36-1 cant remember) so you'll need to have the flywheel machined and a bit of metal let into it to complete the 4 pickup points on 12, 3, 6 and 9 o'clock.
mine uses a bracket that has been alloy welded to the sump, a cosworth crank sensor and bracket and a pulley with 4 pickup points on it - works 100% and theres no machining of parts involved.
Paddy - Field Motorsport will modifiy your sump and pulley if you give them a bell.
Old Nov 26, 2004 | 08:10 AM
Bomber's Avatar
Bomber
Oh and the Zetec sensor uses reverse polarity to the Weber loom/ECU so you will have to cut you loom and swap round the wires.
Old Nov 26, 2004 | 08:13 AM
Paddy rst's Avatar
Paddy rst
cheers for the info lads...
Old Nov 26, 2004 | 08:24 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Using a 1.8 Sierra CVH EFI cam cover
Old Nov 26, 2004 | 08:38 AM
zvhturbo's Avatar
zvhturbo
Ooooops Sorry,
Thought we was talking about a propper management.
Old Nov 26, 2004 | 08:59 AM
St3V3_C's Avatar
St3V3_C
This is what we did for Lewis's Zetec, which is also 36-1, but might be of some help.
Old Nov 26, 2004 | 12:04 PM
Bomber's Avatar
Bomber
St3V3_C: Thats how mine is mounted too and i've had no problems with it.
blackRS: You cant use the 1.8CVH Cambelt/sensor on a Zetec block unless you chop and reweld it up.
zvhturbo: why do you think its not 'proper' management? sounds like you want to see me at the pod?
Old Nov 26, 2004 | 12:51 PM
CozzyBrom's Avatar
CozzyBrom
easyistg way is drill and tap a flywheel and use a cossy pick up
or do what i have done befre use a cozzy bracket and weld allen bolts to back of front pully
the cozzy bracket lines up bang on
Old Nov 26, 2004 | 01:05 PM
B19-TRB's Avatar
B19-TRB
as said thats how we did mine!
the bracket pioctured in these pics was shite! so made a new 1 up(pictured in steve c's post) @ Norris Designs with the help of steve & simon from SECS!
U can also modify the fly wheel so it has only 4 pick ups!
see http://www.zetec-turbo.co.uk/ for more on that
Old Nov 26, 2004 | 01:21 PM
St3V3_C's Avatar
St3V3_C
There was some cool stuff at ND:
Stack 'em and rack 'em Evo's
Go fast gas
Old Nov 26, 2004 | 01:23 PM
St3V3_C's Avatar
St3V3_C
Just noticed Lewis is in every picture that DOES NOT relate to any work being done on his car - lazy get!
Old Nov 26, 2004 | 01:26 PM
B19-TRB's Avatar
B19-TRB
Oi! Me& Dave were workin hard!
Its hard to look @ all that horsepower & not bash 1 out over the bonnet!
ND has got everythi u could ever want in a work shop! twice!
Old Nov 26, 2004 | 02:13 PM
St3V3_C's Avatar
St3V3_C
Old Nov 26, 2004 | 06:15 PM
Paddy rst's Avatar
Paddy rst
so bracket welded to sump and bottom pulley modded looks like the way for me..
cheers again for info everyone
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
griffo69
Oct 4, 2015 11:58 AM
SMILER258
Sep 28, 2015 09:04 AM
