9 or 10 inch rears on a saph
found this one on my computer
dont now how wide they are but i think you can find that here some where
http://www.ellmer-autosport.de/
saff is working!!!...atm
still think wider rears look ace tho .
cheers
gaz .
I dont see the point in fitting 9 -10inch wheels to then stick a tyre designed to fit on an 8inch wheel. Might just be me but i think stretched tyres looks wank. If you are doing it so you can fit wider tyres i think its a good idea and will look very good[back wheels on the white saph for example].
Cossie Rich is the best person to talk to or Martin Hadland. He has 235 R888 which actually measures 243 and they are very tight to the inside, they also had to roll the outer arches.
I have 235/40/18 on 8" with R888 on the rear of mine & they need a fair bit done not to rub under hard cornering or with a full load. Had my arches rolled orginally but have now had them completely cut away to clear. My car is standard road height.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
dojj
28
Sep 11, 2015 10:00 PM
