Cossie parts
Old Feb 6, 2009 | 01:41 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Default Cossie parts
2wd head, measures 138.7, needs a helicoil in one exhaust stud complete with cams,pulleys,and cam cover which has aero breather fitted.
£350+postage
2wd Ford/Buru leads, good condition.£30+post
Chrome pas bracket from 2wd, needs a polish, some pitting in the corners.
£15+post
Chrome alternator bracket 2wd saph/3dr, needs a polish.
£15+post
2wd fuel rail.
£18+post
2wd oil pump and spray bar, good useable condition.
£65+post
2wd diff hanger, surface rust only, would clean up ok.
£30+post
2wd turbo oil supply pipe, this is brand new although was fitted to my car then removed as i have a remote filter with take off.
£20+post
Revotec oil pressure gauge, white face with silver bezel, no lamp fitting, working ok.
£12+post
Assortment of hose finishers, all anodised red, some need new jubilee clips, all fit various hoses on a 2wd saph.
£25+post
2wd sump, good condition.
£40+post
pair saph mirrors, heated and elec ok, in black, would benefit from painting.
£25+post
2wd Auto-specialist stainless turbo heatsheild, needs a good clean and polish.
£85
2wd rear beam brackets, freshly powdercoated in gloss black.
£20+post
3dr rear anti roll bar powerflex/poly bushs, new in packet, bought by mistake.
£15+post
2wd exhaust manifold, no cracks or seized bolts.
£50+post (heavy item)
Pm or ring me with any questions, my number is 07815622710.
Steve
Old Feb 6, 2009 | 04:03 PM
james kiely's Avatar
james kiely
steve would you post the altenater and power steering bracket to ireland ,if you could i,ll have them off you mate.
cheers james
Old Feb 6, 2009 | 08:15 PM
Moonstone Steve.
No problem m8 as long as you pay the postage i will send them anywhere.
Steve
Old Feb 6, 2009 | 08:20 PM
james kiely
cheers steve ,find out what the post will cost and pm me when you get a chance with your preffered method of payment
Old Feb 6, 2009 | 08:28 PM
Moonstone Steve.
Steve
155lee
Sep 6, 2016 11:10 AM
Bransby
Sep 14, 2015 08:54 PM
