help with a non runner xr3i
i bought an 88'spec xr3i.i bought the car as a non-runner.i tryed turning over the engine and i found out that the fuel pump was seized so i bought a new one.when i tryed to start it again it started for a few seconds and cut out again.at this stage it was very smokey.so i took off the inlet manifold an took out the injectors and found 2 were blocked so i cleaned them.after that i tested each one and they were all working as they should.i tryed the car again and it ran for a while but still very smokey.i then wound down th afr an dnow the car is ticking over but when i try and rev it it dies down and cuts out.!
any ideas what is wrong with it.??
Hey...I have a 1990 xr3i efi and its also a non runner...needs a new fuel pump but im having snags locating the correct fuel pump. Do I need to get a new sender unit as the fuel pump is built in with that? Any help would be amazing! Or a point in the right direction! Cheers!
pump should be easy to find alof of cars used the efi cvh
Cheers for that...managed to get a second hand one which works as you can hear the pressure build when you turn the ignition.
But now I have run into a bigger problem which I believe is with the immobiliser.
Only a couple of times did I get the noise from the fuel pump but now it seems that the immobliser is cutting in. I have the fob but that doesnt seem to do anything?!!?
Also, the battery was quite drained at this stage so could this be a contributing factor?
Cheers!!
Cheers!!
