2wd engine breaking
As title
205 block standard bore ( you can still see the honing marks) no lip at the top of the bores £110 ono
Crank Std/Std £ 350 ono
Rods/pistons £120
Oil pump/ pick up pipe £50
Sump £40
2wd head no corrosion complete 138.8mm £350
Bottom end currently still together but will remove parts as requested.
I can be contacted on 07725238098
Regards Steve
Rods/pistons £120
Sump £40
Regards Steve
Oct 9, 2015 07:38 PM
rog
Sep 4, 2015 12:10 PM
lockie
Jul 31, 2015 10:03 PM
