2wd saph idling high
Old Jan 28, 2009 | 02:49 PM
yellowrscustom's Avatar
yellowrscustom
Default 2wd saph idling high
my 88f 2wd saph is idling at 1200rpm when warm-how do i turn the idling down?or is it the idle control valve thats goosed?,its very spluttery when i start it from cold as if its getting to much choke-any ideas on curing this prob also-thanks in advance
Old Jan 28, 2009 | 04:38 PM
Could be a few problems here, if the CTS is more than a few years old I would change it, then get CO set to what chipmaker says as a idling co.
TRy first cleaning the idle speed valve with carb cleaner, then spray inside with silicone polish/furniture polish., if this is still idling high do below.
Then the, screw to adjust the tickover speed is mounted on the underside of the throttle housing pointing forwards, a 14mm nut on a brass screw, loosen locknut and turn screw to adjust tighten locknut.
Be sure to have up to temp, with the idle speed valve disconnected.
Old Jan 28, 2009 | 04:40 PM
yellowrscustom
Thumbs up
brilliant,thanks a lot pal
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
RSmark84
Sep 13, 2015 01:29 PM
dojj
28
Sep 11, 2015 10:00 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
