Weird malfunction of sapphire door indicator/ bulb failure panel!
Guys my door indicator - bulb failure panel is working only if I keep my gas tank full. If the level of the gas tank drops below 3/4 it isn't working!!!
Have you ever experienced this malfunction? What's the reason for that?
HELP!!!!
HELP!!!!
i had loads of probs with mine, nearly every terminal on the multiplug had cracks in the contact where it was soldered to the circuit board, resoldered them all and no probs since!
Well I had replaced the door indicator module with a used one but still it's making the same thing. Any other ideas than the module? The old one was dry and with no cracked terminals...
Tony W
Sep 9, 2015 12:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
