Focus ST Xenon Headlights
Old Jan 26, 2009 | 11:20 AM
djsri's Avatar
djsri
Default Focus ST Xenon Headlights
I have a 56 plate Focus Titanium with these cheap style (ebay) headlights in. If i was to buy some 07 plate ST Xenon headlights would they work as a direct replacement?
Old Jan 26, 2009 | 11:41 AM
Fezza's Avatar
Fezza
H71 CNX
As long as you get the ballast units I dont see why not.
Failing that, fit some aftermarket HID lights into your standard reflectors. My fezza has them and they look the nuts at night.
Old Jan 26, 2009 | 03:53 PM
djsri's Avatar
djsri
Hi
Thanks for the reply
I have the ST Xenon lights all complete but i couldn't get the Xenon part to work? Full beam/side lights and indicators worked fine just no Dip beam. Do you know if the wiring is different on the ST? my headlight plug has three pins less than the headlight.
Old Jan 26, 2009 | 04:03 PM
Jonsen's Avatar
Jonsen
Originally Posted by djsri
Hi
Don't know much about the FST but thats most likley for the auto levelling feature. Does the lamp not light at all or flicker then go out? You may have to uprate the wiring as the Xenons take a large current at startup in order to ignite the arc.
Old Nov 3, 2011 | 11:21 AM
cuffmillerparts's Avatar
cuffmillerparts
Default Focus ST/RS 2008-2011
I have 5 sets of Focus LHD Xenon Headlamps avlailable.
Contact
lester@cuffmiller.co.uk
Old Nov 3, 2011 | 12:58 PM
mcdavep's Avatar
mcdavep
The earth is on a different pin u need to join them up
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Mile30
69
May 13, 2017 08:44 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
Kam B
Sep 24, 2015 10:40 AM
