2wd cossie diff
Old Jan 26, 2009 | 10:36 AM
stumpy's Avatar
stumpy
Default 2wd cossie diff
I am running over 500 bhp through my 2wd diff and dont think it will last much more. What is the strongest diff to run and where would be the best place to get one from?
Thanks
Stumpy
Old Jan 27, 2009 | 06:26 AM
A lot go for the jag option, not a simple bolt in though.
Old Jan 27, 2009 | 11:38 AM
Vic's Avatar
Vic
in terms of 7.5" diffs, there are at least 3-4 options tat will cope with 500hp. The weak link though is the CWP.
Alernatives are the
*Jag 10.5" (very heavy but can take lots of hp and torque),
*Ford Mustang IRS 8.8" (requires custom fabrication, but is sweeeet -choie of David Godfrey, LINCOLN and me! LOTS of ratios and diff types eg plated, spool, ATB type),
*Ford Motorsport 9" (ultimate, but a little rare to find in the right ratio, plated or viscous),
*BMW diff (requires custom mounts and axles but lots of ratios).
Old Jan 31, 2009 | 04:34 PM
stumpy's Avatar
stumpy
Thanks for your help have got one cmming from graham hathaway racing.
Old Jan 31, 2009 | 04:40 PM
Vic's Avatar
Vic
cool which did you end up getting?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
mark r
Sep 29, 2015 07:27 PM
Fezman1
Sep 7, 2015 09:34 PM
