st abs ecu where is it?
Old Jan 23, 2009 | 11:36 AM
liamford's Avatar
liamford
Default st abs ecu where is it?
does anyone know the location of the abs ecu in the small turbo escos',
thanks guys
Old Jan 23, 2009 | 02:02 PM
Dave Henshall's Avatar
Dave Henshall
same place as the BT, in the left hand side of the boot, behind the carpet trim, sits at an angle.
Old Jan 23, 2009 | 03:26 PM
liamford's Avatar
liamford
thanks mate!
Old Jan 23, 2009 | 03:27 PM
liamford's Avatar
liamford
are the ecu's the same as the bt? think mine is playing up and need a new one.
Old Jan 23, 2009 | 05:59 PM
ECOS95's Avatar
ECOS95
I don't think they are but can't be 100%.
Old Jan 25, 2009 | 09:17 AM
Dave Henshall
99% sure they are the same - also the same system as on early scorpios - it is a differnent system to the saphs though , although it does use the same wheel speed sensors.
what symptoms are you having?
Old Jan 25, 2009 | 11:00 AM
liamford's Avatar
liamford
when i slow down from speed its ok untill about the last 5yrds and the abs kicks in and the pedal goes stiff and juddery, its only the last 5 yrds of slowing. ????......?
Old Jan 25, 2009 | 11:31 AM
The Youth.'s Avatar
The Youth.
deffo sensor fault, take them all out and clean them and check the groves in the shafts and clean them also.
very common problem
steve
Old Jan 26, 2009 | 12:20 PM
liamford's Avatar
liamford
cheers fella will get straight on it!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
