Which brake upgrade ST24
Hello All,
I'm seriously thinkin of upgrading the brakes on my Mondy to EBC grooved or drilled and grooved.
Anyone done this and notice dramatic improvement.
Running Green stuff pads.?
Where would you best advise I get the lot from EBC direct or elsewhere.?
Why not fit the mondeo mk3 front calipers and the focus st170 300mm discs, that what i have done and it is a good upgrade.. i fitted mine along with grooved discs green stuff pads and braided hoses.
Looks sexy as fook Dave.
How much did all that cost though.? I was hoping not to need to change the calipers themselves, though I realise the Mk3's might be a whole lot better.
mk3 calipers are around Ł50 - Ł70 a pair.
the 300mm st170 grooved disks are about Ł70 a pair. greenstuff mk3 pads can be had for Ł30 a set on ebay.
its well worth doing, the brakes are rock solid on mine since i done that same conversion.
Those prices are spot on that is about what i paid, and about 35-40 quid for the braided hoses.
I uprated the rears to, just fitted standard dized grooved discs and green stuff pads.
Rears
Pic of all the bits before fitting..
Rears
dont use green stuff pads if want to die they are crap so are their disc the friction bit of the pads brake off and vibrates like hell just changed mine over the easter,got some mrk3 calipers and brackets form work brand new rs focus caliper bolts and 12X 1mm spacers std st170 dise and std mrk 3 mondy pads for now what a difference it made was alsome when bedding them in at 60mph left metre skid marks and the car runs abs to on the old mondy
check this link for more pics also pic's of green stuff crap
http://www.fordmondeo.org/forum/show.../post/new/#NEW
