3dr 4x4 anti roll bar?
just wondering if i can fit a 4x4 antiroll bar with the 4x4 rear arms to a 3dr beam? will this work and be a direct fit plus will it be better than the 3dr roll bar?
thanx maca
thanx maca
It is a massive improvemnt to the std 3 door bar, which doesn't really do much, had these on my xr4i, useless is an understatement.
If using 4wd arms this will allow it to fit to the arms, but where it goes on the flat section and is held with the arb clamps, the slots and threaded holes are not likely to be there, but a simple bit of welding/fabrication soon sorts that, well worth it for the difference.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
Tony W
Sep 9, 2015 12:08 PM
