GT3071r
hi,
this is a genuine garrett turbo, external wastegate, brand new
the specs are as follows
.50 a/r 4inch inlet
71mm 56 trim wheel
flow: 46lbs/min
max WHP rating: 475whp
Turbine
T2 flanged .86 a/r
57mm 90 trim wheel
at the current excahnge rate will cost over £1000 delivered to your door:
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
Im only asking £540 delivered, comes with a gasket aswell.
Dave
.50 a/r 4inch inlet
71mm 56 trim wheel
flow: 46lbs/min
Turbine
T2 flanged .86 a/r
57mm 90 trim wheel
Dave
escort_rst
Jul 10, 2015 07:21 PM
