Alloy header tank with aeroquip fittings!
As in title. Full aeroquip connections included so NO jubilee clips required! Also included is the steel braided water return pipe. The powder coated header tank isnt to everyones taste but it can easily be repainted if required. The tank has a valve fitted also to allow a cold system to be pressurised and also to allow safe cap removal on a hot pressurised system.
£90 delivered!
Cheers. Adam.
07968545399.
£90 delivered!
Cheers. Adam.
07968545399.
As in title. Full aeroquip connections included so NO jubilee clips required! Also included is the steel braided water return pipe. The powder coated header tank isnt to everyones taste but it can easily be repainted if required. The tank has a pressure release valve also to allow safe cap removal on a hot pressurised system.
£90 delivered!
Cheers. Adam.
07968545399.
£90 delivered!
Cheers. Adam.
07968545399.
that valve was fitted to enable the system to be pressurised not to let it off, though it would do both
steerfromdarear
28
Jan 29, 2016 06:14 PM
Oct 9, 2015 07:38 PM
Danielbetty
Aug 23, 2015 08:25 PM
155lee
Aug 14, 2015 11:21 AM
