Anyone got 1 of these or know where I can get 1 ASAP???
Old Jan 17, 2009 | 07:57 PM
adam.d's Avatar
adam.d
Default Anyone got 1 of these or know where I can get 1 ASAP???
I need 1 of these pipes with the 1 way valve in, anyone got 1 local or know where I could pick 1 up from? are they used on any other cars?
Old Jan 18, 2009 | 01:46 PM
B16CVH's Avatar
B16CVH
Im 100% sure ive got one, will have a look in my aladdins cave!
Old Jan 18, 2009 | 03:44 PM
Rick's Avatar
Rick
Bin it off mate. Run a pipe from the rocker straight to the large diameter pipe that goes to the metering unit. Don't have anything connected to the inlet.
Old Jan 18, 2009 | 04:43 PM
adam.d's Avatar
adam.d
Won't that just allow oily vapour to enter the meter head?
Old Jan 18, 2009 | 04:55 PM
B16CVH's Avatar
B16CVH
This creates too much suction to the oil system, this results in an oil rich mixture entering all the turbo pies, intercooler and eventually the combustion chamber....this is not good at all as it increases detonation! The suction on the oil system must be minimal or vent to atmosphere (on non metering unit cars).
Old Jan 18, 2009 | 05:25 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
It shouldnt even have that 1 way valve on. Thats off a brake servo it should be just a straight pipe. someone correct me if im wrong.
Old Jan 18, 2009 | 05:32 PM
Rick's Avatar
Rick
yes, which is what it does as std. The valve is there so as not pressurise the system on on boost., and draws vapour in at idle straight into the inlet - this is a legal emissions requirement. What the used to do on the race 3i's which aren't allowed seperators, is block the metering inlet, and run the rocker outlet into a plastic bottle, but obv dont seal the pipe. Depending on how heavy the engine breathes, you empty the bottle of oil every so often. Of course, best thing is to get an oil seperator.
Old Jan 18, 2009 | 05:34 PM
B16CVH's Avatar
B16CVH
As above
Old Jan 20, 2009 | 09:35 PM
Tim's Avatar
Tim
yeah your wrong its as rick says.
tim
Old Jan 20, 2009 | 11:10 PM
©hatter Box's Avatar
©hatter Box
thats upside down
Flatlinedan
Sep 18, 2015 12:41 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
syathome2000
Jul 27, 2004 01:32 PM
Fudgey
Jul 21, 2004 10:11 PM
