SILVERTOP CAM COVER OILBREATHER
Old Nov 23, 2004 | 06:09 PM
fordrallycar's Avatar
fordrallycar
Default SILVERTOP CAM COVER OILBREATHER
HI ALL
I HAVE A SMALL TURBO ESCORT COSWORTH WITH THE SILVER TOP I WANT TO FIT A OIL BREATHER BUT NOT SURE HOW IT FITS.IE DO I STILL HAVE TO DRILL OUT THE BACK CAM COVER OR NOT??
ANY HELP WOULD BE GOOD
CHEERS PAUL
Old Nov 23, 2004 | 08:19 PM
Glenn5's Avatar
Glenn5
ive seen small turbo escos with drilled cam covers in front and in bk like original cossy covers or you can go 4 a bailey style 1 without using the cam cover take off and run 2 block or separator tank mite pay 2 ask the pros tho m8. maybe contact 1 from the board
Old Nov 26, 2004 | 03:05 PM
ESCYSCOTT's Avatar
ESCYSCOTT
you dont need to put the breather in the cover mate, small turbo heads are different than large turbo ones...............these dont breath the cover, there is a vent that runs through the head and block down to the sump and that is what it is breathing.....you need a two port breather for the small turbo
Old Nov 29, 2004 | 12:57 PM
Dave Henshall's Avatar
Dave Henshall
the same would apply as here ...
https://passionford.com/forum/viewtopic.php?t=87573
mk3ste
Oct 17, 2021 10:09 AM
Mark RS
Mar 5, 2021 06:08 PM
