zetec rods
Power conversions have had their zvh turbo engines up to as much as 280 bhp, they recommend/advise that 200 - 250 is the safe mark but this is only with spot on fuelling, I think mfi would struggle to get this sort of power but efi with the correct injectors would be fine.
Hope that helps
Hope that helps
i personally wouldnt want to gamble with standard pistons as a slight hicup could cost your engine. Ive heard people using toe rods @ 280hp as rough limits, bud id imagine torque is more what kills them?
a friend of mine has been using xe pistons, standard rods and arp bolts on his mfi with fith injector. He got 267bhp at16 psi. It seems to me that 280 would be the max and 250 sensible.
anybody else got good reasults
I am led to believe whilst torque can obviosly kill a rod it is far more likely to be revs, failure occuring at the top of the exhaust stroke! As it has no force pushing down on the piston.
I spent alot of time with Harvey Gibbs sorting a spec for a silver top and he reckons with ARP bolts they are good for 290bhp as per a couple of engines he has done with no failures!
My 2.1ZVH ended up at 294bhp at 28 psi with an occasional trip to NOS on arp'd standard rods and it never let go! did a good 15K on that engine, giving it death!
sean
Cheers Rick, your quite correct!
You have to put it into context though. A rod will break when the torque and speed exceed a maximum figure.. I'm no physics expert, so lets use bananas as a unit. An 8300rpm 140 ft-lb n/a engine may have a sum of 50 bananas, which may be less than a turbo engine with 300 ft-lb @ 6000rpm at 70 bananas.
i had 262bhp in full zetec form with cp pistons, arp rod bolts but it let go after 12500 miles but i had efi n will running toooo much boost n it left a nice hole a the front of the block
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
