no 2-4-reverse gear
Old Jan 16, 2009 | 01:41 PM
cossiewill.'s Avatar
cossiewill.
Brit With A Tan
Default no 2-4-reverse gear
Hi guys
I am not able to put my saph into 2-4-reverse gear.
1-3-5 works fine, or should i say it goes in gear and moves forward.
Ww
Old Jan 16, 2009 | 02:56 PM
cossiewill.
Brit With A Tan
opps double posted
please add your comments here.
https://passionford.com/forum/showthread.php?p=3881607
Ww
Old Jan 19, 2009 | 04:01 PM
cossiewill.
Brit With A Tan
Hey All
So i posted this in the tech section but i have not had to much sucess.
Sad really
But i think i will have to just start puttig all my post in this area.
Ww
Old Jan 20, 2009 | 10:17 AM
cosworth87's Avatar
cosworth87
chek the rear. gearbokmount if its broken the gearbok falls down in the rear.
Old Jan 20, 2009 | 10:49 AM
cossiewill.
Brit With A Tan
Hi cosworth87
Is that the mount behind the gear shifter. o you have any pics of where it is?
Ww
Old Jan 20, 2009 | 11:05 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's the 4wd box then check the gearbox cradle where the selector sits, if the bolts have come out it'll be an arse
Old Jan 20, 2009 | 11:39 AM
cossiewill.
Brit With A Tan
Hi dojj
It is a 4x4. If the bolts had come out then would i only be able to get it into 1-3-5?
Ww
Old Jan 20, 2009 | 02:13 PM
dojj's Avatar
dojj
there are 4 bolts, 2 on the side at the back and 2 at the front on the top
if the back ones come out it'll be difficult to put it into the gears you mention
if the front ones come out then it'll be difficult to get inot he gears you can get now
poly replacements are available or i'm sure i read somewhere that the likes of martin @ reyland do solid ones
make sure there is a decent thread in the ali casing though as they have a habit of stripping, so maybe helicoils will do the trick
funnily enough, you are the second person this week who's had the same problem
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
