HIGH COMP?
Old Feb 19, 2004 | 08:11 PM
Default HIGH COMP?
just heard from Ima Racing 500 that his car runs a high compression engine. how does this work as ive heard it mentioned before but never really had any info on them. if you lot could give me as much info as pos i would greatly appreciate it
thanx
p.s - what management do i need for anti-lag?
Old Feb 19, 2004 | 08:18 PM
Doug's Avatar
Doug
Not sure about comp question but ALS your better off getting pectel or something similar
Regards Doug
Old Feb 19, 2004 | 11:13 PM
PJay's Avatar
PJay
DaveRS you have PM
Old Feb 22, 2004 | 07:30 PM
hello dave, i think they increase the compression ratio on the engine to improve the pick-up off-boost
Old Mar 2, 2004 | 12:52 PM
ALS can only be run with P8 or anything above
ALS needs a brainy ecu ya see
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
