msd chip for level 8, gauges etc, offers needs to go
msd chip, again very little use
this is for a red top level 8 ecu, to run 55lb siemen injectors, 3 bar, comp ratio is 7.2-1, also includes closed loop aswell, cost me £360
so im looking at £150 inc postage which is half price, the chip can also be sent back to stu for upgrades or downgrades or altered to suit your needs but i dont know how much he charges
another chip, bought off racetek when i first got the cossie on the road, level 8 non cat, std engine, greens, 3 bar perfect working order
£20 inc postage
all payment methods accepted bar bank transfer, paypal preffered though
anymore pics please ask
also have a bare rear beam, all polybushed, minus rollbar, but its bare £20 collection only, was powdercaoted black and silver
4wd front roll bar £20 collection only
4wd cosworth forged racing pistons 7.2-1 compression ratio, 0.25th oversize and valve pockets
they do need new rings as the rings failed on me, complete with gudgeon pins and circlips
open to offers, please bare in mind these are £800 pistons new and you can get rings from cosworth for about £150
£20 inc postage
just need a lambda sensor, 4wd cos looms have the lambda plug in there std anyhow, so just all plugs up
but i think i have someone interested in it, so will let you know
will do mate
take alook on the drivers inner wing for a 3 pin triangle plug, with like a heat sleeve round it, if you have this and are running a level 8 then id imagine it will work as that plug is the lambda
still on l6
changing over to l8 when i get the chip
got everything i need except chip as i was getting that last in case i changed the spec at any point, but thats everything sourced now ready to fit
dont think the 2wd's had the plug for the lambda but i'll check anyhow
let mr know either way mate
sorry mate, realy want this chip but cant justify the extra cost of it,
i'm sure you understand
if you drop the price any let me know and i could be interested
£20 inc postage
£20 inc postage
2)the heater element wires(both white) need to be run to a live and earth,we recommend the chassis as an earth point and the fuel pump relay positive output as a live source,this ensures the current hungry heater is only powered when the engine is running
also must but remove the two wires of TPS and return around (not the middle wire).
anyone
carnt be arsed with ebay either, carnt beleieve these havnt shifted considering the price of the chip new and this one can be sent back to be modded by stu at a little cost aswell
its less than half price of a new one and this one is only been in my car for less than 4k
Mark RS
Oct 12, 2015 06:01 AM
