What is this?
Old Jan 15, 2009 | 04:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default What is this?
There is an 'item' that sits below and to the left at the back of the inlet manifold with one pipe going to the throttle body and the other going to the back of the inlet manifold, is it an idle speed control valve?
The reason i ask is that i have an air leak and i can here air being sucked in from the back of the manifold, i think the pipe that joins this 'item' to the inlet may be leaking.
The car idles badly for about 30sec then clears during which time the sucking i can here quiets down.
I have scoured ebay but cant find any such pipes and only one ICV but it's for a EFi RS and looks different to what i have, so i'm not sure.
Any help appreciated!
Old Jan 15, 2009 | 04:26 PM
adam.d's Avatar
adam.d
Is it the Auxilery air valve?
mine was leaking on mine (mfi) and I got another off a mate, also have a spare 1 if you need it
Old Jan 15, 2009 | 04:27 PM
JamboRS's Avatar
JamboRS
focus rs 1672
aux air sensor mate
the aux air valve allows air through to help the car tickover when its started from cold
edit :damn to slow lol
Old Jan 15, 2009 | 04:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ah!!! Yes that might be it!!
How much do you want for it, do you have the pipes too?
Old Jan 15, 2009 | 05:07 PM
adam.d's Avatar
adam.d
Nah, don't have the pipes mate. If you need it then you can have it
pm me your address and I'll post it to ya
Old Jan 15, 2009 | 05:19 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Spot on mate!!!
Old Jan 15, 2009 | 05:28 PM
grsford's Avatar
grsford
i have a complete inlet if you need anything and your only down the road
regards
Old Jan 15, 2009 | 05:33 PM
Karlos G's Avatar
Karlos G
Balls Deep!
regards
Cheers!
I may need the pipes if i find mine are shit, i'll PM you if thats ok?
