New Transit front discs..
Old Jan 15, 2009 | 11:33 AM
James's Avatar
James
Default New Transit front discs..
anyone know what sixe the torx bolts are that hold the disc to the hub? t50 or t55?
Old Jan 15, 2009 | 04:10 PM
rst in breaking's Avatar
rst in breaking
just curious, im guessing these are the same as a 51 plate transit but i couldnt get my discs off the over week, i undone the 5 or 6 bolts or however there were and removed the nut off the driveshaft then tried an extractor and it wouldnt come off? am i missing something? (sorry to highjack your thread lol)
Old Jan 15, 2009 | 05:35 PM
DangerousBryan's Avatar
DangerousBryan
the torx bolts are t50. on all of them from y reg on you remove the caliper, remove the dummy cv joint if it is a rwd or the bottom ball joint and the driveshaft if it is fwd. then remove the t50 bolts through the holes in the hub. next you have to wind some bolts of the same thread in from the other side of the hub. make sure they are long enough to push on the back of the 13mm bolts. just use 2 on opposite sides to each other and these will push the hub/disc out. then undo the 13mm bolts and knock the disc off the hub.
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
Adam-M
Aug 27, 2015 08:55 AM
SteveyDee
Aug 25, 2015 07:48 PM
C2 MAK
Aug 20, 2015 09:46 PM
