poxy cheap safe!
Old Jan 15, 2009 | 09:37 AM
GavStyli's Avatar
GavStyli
Kasapis
Default poxy cheap safe!
mate has a digital safe he bought from homebase a couple of years back
the key pad still works but doesnt accept the pin number anymore
obviously these safes have overide keys but dont help when youve lost them too!
any ideas? anglegrinder or drill the hell out of the key hole or something?!
can see why it only cost £25 now
Old Jan 15, 2009 | 09:58 AM
ballin's Avatar
ballin
grind the hinges off? if its that cheap, it wont be too hard to get into
Old Jan 15, 2009 | 10:00 AM
nigel b's Avatar
nigel b
if its an electronic keypad there is usually a battery back up
Old Jan 15, 2009 | 10:03 AM
GavStyli's Avatar
GavStyli
Kasapis
its this one, battery hasnt gone flat, its just playing up and forgotten its pin number
http://www.homebase.co.uk/webapp/wcs...ity%7C10482974
Old Jan 15, 2009 | 10:15 AM
SteveH's Avatar
SteveH
Pick/drill/smash the lock? Usually behind the keypad
Old Jan 15, 2009 | 12:20 PM
Farmer Giles's Avatar
Farmer Giles
what ever you do make a video of it..
Old Jan 15, 2009 | 04:13 PM
philpy-si's Avatar
philpy-si
Angle Grinder, Air Chisel, Gas Axe! Whatever, reckon its gonna be fun!
Old Jan 15, 2009 | 05:20 PM
RS Grant's Avatar
RS Grant
Made in Scotland
You're gonna have to do it by touch.
Cheers,
Grant
Old Jan 15, 2009 | 05:30 PM
RichieST's Avatar
RichieST
Get some braniac thermite on it
Old Jan 15, 2009 | 05:42 PM
~nomad~'s Avatar
~nomad~
twat it right on top with a sledgehammer, door will pop off.
Old Jan 15, 2009 | 05:53 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i belive a tank firing a missile at it will open it
Old Jan 15, 2009 | 05:58 PM
Stu.H's Avatar
Stu.H
Next question: Where can I get a tank and a missile
Old Jan 15, 2009 | 06:00 PM
RichieST's Avatar
RichieST
Swindon
Old Jan 15, 2009 | 06:03 PM
JTECH James
Passion for Fords!
ebay....
Old Jan 15, 2009 | 06:36 PM
SteveB's Avatar
SteveB
Mine does the exact same and I've lost my keys to it as well (put them somewhere safe but can't remember where......lol) I just keep putting the pin in until it works sometimes takes 20 or so goes....
Steve
Old Jan 16, 2009 | 08:04 AM
999's Avatar
999
depends on the safe
the cheap ones are easy, you need to get access to the wire for the motor, some are real easy the emergency key hole open is behind a scew in panel, you can use a tool to pry int here and hookt he wire out put a batter on it and it opens only takes a couple mins
others you will have to drill an get in there and fish round for the wire.
Old Jan 16, 2009 | 08:06 AM
ECU Monitor Enthusiast
Call a lock smith
Old Jan 16, 2009 | 08:08 AM
999's Avatar
999
he wont need one ona cheap safe, even at a last resort a angle grinder with a metal cutting disc will open it in 10 mins
Fiddy
21
Sep 29, 2015 06:10 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
marky_g
Sep 12, 2015 04:26 PM
