Radiator Fitting
Old Jan 14, 2009 | 09:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Radiator Fitting
Does anybody know if you can change the radiator without removing the turbo?
As i've only just fitted the turbo and didnt want to take it off again but my rad has sprung a leak
Old Jan 14, 2009 | 10:06 PM
ZVH,RST's Avatar
ZVH,RST
Smile
yes, bumper off intercooler off then the rad comes off from the front.
Old Jan 14, 2009 | 10:11 PM
Marts's Avatar
Marts
As above. Simple
Old Jan 14, 2009 | 11:03 PM
addiction's Avatar
addiction
spot on!
Old Jan 14, 2009 | 11:14 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
long as u can get them fookin 10mm bolts out the rad tht connects it to the intercooler,lol
Old Jan 15, 2009 | 01:56 AM
Smartdj.'s Avatar
Smartdj.
i didnt enjoy tkin mine out..some of them bolts are kunts
Old Jan 15, 2009 | 09:12 AM
orion88's Avatar
orion88
as above take the bumper of is the easiest
Old Jan 15, 2009 | 03:49 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Arse!!
My bumper is a twat to get off (being quality fibre glass!!) and i'm running a FMIC so will have to remove that also.
Cheers!
Old Jan 15, 2009 | 03:58 PM
RSandy's Avatar
RSandy
it is possible to take it out with the turbo in position, but much like when u remove the turbo and u have to take care not to contact the rad in that case, this becomes the opposite lol
its an arse of a job basically, but possible if your careful
Old Jan 15, 2009 | 03:59 PM
RSandy's Avatar
RSandy
oh, also will depend how snug your fmic is to the rad, as that will limit the angle of attack somewhat
Old Jan 15, 2009 | 04:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Hmm think i'll just have to remove the bumper... probably the best bet!
Old Jan 15, 2009 | 09:24 PM
sm's Avatar
sm
one trick is if u remove the rad with the turbo still fitted stick a peice of cardboard to the rad so if u do knock it against the turbo it wont cause any damage
Old Jan 15, 2009 | 09:26 PM
smila's Avatar
smila
ye take bumper off only took me an hour to take it off and put it all bk together first one ive done aswell
kellyalfie's Avatar
kellyalfie
spot on mate had to do that when fitted A&S RAD &COOLER
Old Jan 15, 2009 | 11:58 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Can you do me a MASSIVE favour please?!?
Measure the radiator?, I need dimensions for a ERST rad, and can't find them anywhere.
Thanks if you can
Old Jan 16, 2009 | 03:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thanks if you can
Yes mate no problem!
As soon as it arrives i'l meassure it up for ya and send you a PM!
Old Jan 17, 2009 | 06:06 AM
Charlie Chalk
Unknown.
No need now mate, sorted as per other post, Thanks though!
Old Jan 17, 2009 | 09:02 AM
Karlos G's Avatar
Karlos G
Balls Deep!
ok cool!
SmudgerByName
52
Jul 28, 2016 06:14 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
