Focus RS brakes onto a 4x4 saff
Old Jan 12, 2009 | 08:00 PM
jemis's Avatar
jemis
Default Focus RS brakes onto a 4x4 saff
Has anyone fitted a focus rs front brake set up on a 4x4 saff, ifso what is needed, is it just a case of getting brackets made up and ifso does anyone know where I can get them.
Old Jan 13, 2009 | 09:02 AM
jemis's Avatar
jemis
anyone tried it
Old Jan 13, 2009 | 09:46 AM
SteveH's Avatar
SteveH
iirc, the saff brakes are trailing edge and the FRS ones are leading edge. I dont know if that would be a problem. I seem to remember when I collected my AP's there was a little confusion over pistons sizes and order regarding leading/trailing specific calipers, though I cant remember the details now as it was ages ago
Im sure you could get brackets made up to fit them though.
Old Jan 13, 2009 | 09:58 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Kelv is selling a FRS brake kit and i think it might be a full kit.
I'll look for the link, brb.
Old Jan 13, 2009 | 12:29 PM
jemis's Avatar
jemis
I would think that would be the case with different size pistons in the caliper but that would also make them sided, I used to have some 6 pots that had 2 big and 4 smaller pistons in each caliper.
I might be wrong but if that is the case I would think they could be swapped over without too much hassle.
The brakes are on there way to me so I haven't seen them in the flesh yet, I'm just trying to find out any problems I might have, like can I use the focus disc's etc.
Old Jan 13, 2009 | 12:58 PM
costina's Avatar
costina
Live long and prosper!!
you can but its a pain in the ass due to offset of discs you really need a 355mm rotor and bell to use those calipers
An expensive conversion as i tried on a mates escos,cheaper to find a s/h set up imo
The focus disc will foul the steering arm sorry,you will need a flatter style disc.I even tried a pug v6 305mmx28 disc but theres not enough room for the brackets
hope this helps a bit
Paul
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
jason_nike
Aug 18, 2019 10:53 AM
mrmann
Aug 20, 2015 11:24 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
c20tbo
Aug 17, 2015 10:19 PM
