Removing...Part 2
Hi all,
I want to remove mr rear brake compensators so I can clean them up and get the out the way whilst painting my underside, I have loosened off all the brake lines that go into them, and only snapped one plastic clip!
fook they were on tight!
But, obviously when I take them out they piss with brake fluid, how can I remove them and stop the brake fluid dripping, is there a way? or do I need to let it drain?
Cheers for any help.
But, obviously when I take them out they piss with brake fluid, how can I remove them and stop the brake fluid dripping, is there a way? or do I need to let it drain? Cheers for any help.
Cheers Dave.
I sure I got a bleed kit somewhere, will just do that then, fook it wot do I need brakes for now eh?
Would of have to bleed them n e way when fitting new rear discs and front setup
Cheers mate
Cheers mate
