baileys breather system
Old Jan 7, 2009 | 08:38 PM
Smartdj.'s Avatar
Smartdj.
Default baileys breather system
iv got one on order and was wondering wether i actualy need the fitting kit for it..or can i use my exicting pipe...as there silicone...and is the fitting kits pipes silicone because £28 for normal pipes is crap...im just a bit confused
Old Jan 7, 2009 | 09:47 PM
bigryrs's Avatar
bigryrs
RSHoleinator
the fitting kit is only 25 quid lol get it bought
Old Jan 7, 2009 | 10:47 PM
Smartdj.'s Avatar
Smartdj.
im not buying it if i dont need it
Old Jan 8, 2009 | 08:09 AM
Marts's Avatar
Marts
I bought a metre length of silicon pipe off ebay for £9 and cut it to size. Ya can use the original jubilee clips from ya existing pipes.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=290274754174
Reason for the new pipe is beacuase you need to replace the old main breather pipe,mainly cos the original breather is built into it, and its plastic
Old Jan 8, 2009 | 08:16 AM
Marts's Avatar
Marts
As for fitting instructions (if ya didnt already know):
https://passionford.com/forum/ford-escort-rs-turbo/272938-fitting-a-bailey-oil-breather-help.html
Old Jan 8, 2009 | 09:18 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Remember you can't use normal Silicone hose to carry oil or oil vapour!!
Old Jan 8, 2009 | 10:03 AM
Marts's Avatar
Marts
I've had no issues with it. The only issue i have ever had like that was when using silicon vaccum hosing for the old breather to inlet connection... that breathed the oil out of it! lol
Old Jan 8, 2009 | 10:10 AM
Christian and Beccy
#1 in Spelling Club
It goes brittle and discoloured.
Old Jan 8, 2009 | 10:20 AM
Marts's Avatar
Marts
oh ok, I'll keep an eye on that then. Thanks for that bit of info.
Old Jan 8, 2009 | 11:43 AM
Smartdj.'s Avatar
Smartdj.
wicked thanks for your help guys and ill save the link..
Old Jan 8, 2009 | 03:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah the ebay link hose is no use!
You need this type mate http://cgi.ebay.co.uk/BLUE-5-8-16mm-...713.m153.l1262... and i think from memory i needed just over a metre so had to buy 2 metres!
Old Jan 8, 2009 | 10:12 PM
Marts's Avatar
Marts
I still have left overs from my metre length, but then i didnt connect it to the metering unit. Ill check that link out and maybe replace my tubing with that.
Old Jan 9, 2009 | 07:13 AM
Karlos G's Avatar
Karlos G
Balls Deep!
yeah if you didnt go to the metering unit then 1 metre will be enough.
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
