small turbo head gasket part number?
anyone know it?
been enquiring at my local ford dealers as read on here it's as good if not better than a group a gasket but the part number comes up the same on the system there when they searched for just a standard 2wd saph gasket and a small turbo escos gasket.
well the problem with getting both is they are both on back order so can't order them in to have them sat on the shelf.
might be easier to order from elsewhere but i can get some very nice discount at ford just need to get the damn part number!
I have 3 of these under my bed
I checked on Microcat and indeed there's only 2 different partnumbers for the headgasket,on the 3 gaskets is says:
50RNZ01
21RNZ02
27RNZ02
And a Victor Reinz number:REINZ AFM10 1 30 2
Hope this helps you
50RNZ01
21RNZ02
27RNZ02
Hope this helps you
steerfromdarear
28
Jan 29, 2016 06:14 PM
