Installed a new cam an still rattling
Old Nov 22, 2004 | 01:38 PM
davidnormanuk's Avatar
davidnormanuk
Default Installed a new cam an still rattling
Installed a new cam yesterday. Ran it for 20 mins at 2,500 rpm and then took it for a gentle run out for about an hour.
Driving to work this morning and noticed that there is a top end noise there like a tappet noise.
What could it be. Would it take a few hundered miles for the cam and followers to bed in properly?
Hope someone can help.
Dave
Old Nov 22, 2004 | 03:11 PM
james_birch's Avatar
james_birch
still trying with mine!
been nearly 200! but got a fuel leak now.... ARSE!
cars off road for a while!
Old Nov 22, 2004 | 03:57 PM
adamS2RST's Avatar
adamS2RST
Where it leaking James?
Old Nov 23, 2004 | 01:20 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
all torqued up proper? squeezed all oil from tappets? new cam and tappets not old tappets/new cam etc?
Old Nov 23, 2004 | 06:05 AM
bigmatt-s2rst's Avatar
bigmatt-s2rst
might be wrong, but mines just started makin a similar noise and its the cam belt tensioner thats makin it??? worth a look if yove put a new cam in??
Old Nov 23, 2004 | 01:58 PM
bassboy's Avatar
bassboy
cud be ur tappets m8, either one is fooked or its just needs to build up pressure again...give it a few days and see how you get on...i had the same problem but cured within 2 days
bassboy
Old Nov 23, 2004 | 05:20 PM
davidnormanuk
I'll have a look at the tensioner and let you know. Seems to be coming from under the rocker cover though. Its is a brand new cam and tappets. Plenty of oil there n all. I'll give it a couple of hunderd miles and see if it gets any better. If not they'll be going back.
Dave
Old Nov 24, 2004 | 01:53 PM
lamar69er's Avatar
lamar69er
poor oil pump, low oil pressure. Did you change all the gaskets on the top end, e.g. cam seal, maybe try re-lapping the valves etc... all cvh's are noisey, my sounds loud but im using double valve springs and anti-pump lifters.
also you need to change the tappet\lifters at the same time when changing the cam otherwise the tappets will wear funnny and vice versa with the cam.
Ive known people just change the tappets on an old cam and within 20 miles there noisy again becase they've warn to the old cam!
