Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
XR2i with 1.6 ZT breaking
Old Jan 3, 2009 | 04:55 PM
Mr.T's Avatar
Mr.T
Default XR2i with 1.6 ZT breaking
My mate is breaking his 2i. It has a 1.6 ZT i know. Running on KMS management. Full kit. T3 turbo is sold. the exhaust mani is made to fit a T3 on it.
Car running
http://s152.photobucket.com/albums/s...t=MOV04637.flv
So heres the list.
Rover turbo inlet £50
Adaptor plate from head to inlet. £40
315cc injectors 16ohm£40
Escos fuel pump allmost new.£50
Wiechers front strutbrace£50
Wiechers rear strutbrace£40
Readhp 280mm steering wheel. Allmost new. Incl hub£70
10row(spelling?) oil cooler. 230mm long £80
Exhaust mani is SOLD
Might have more just send me a PM
pics
Old Jan 3, 2009 | 05:03 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
selling the mangment?
Old Jan 3, 2009 | 05:06 PM
Mr.T's Avatar
Mr.T
Yep. But you are not going to like the price tho. KMS is a expensive management.
Old Jan 3, 2009 | 05:17 PM
clarke5700's Avatar
clarke5700
lol thort i would ask. how much then?
Old Jan 3, 2009 | 05:30 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I don't suppose you have a photo of the inlet manifold and adapter plate fitted together to show the port matching?
Old Jan 3, 2009 | 05:33 PM
Mr.T's Avatar
Mr.T
No sorry. But i could ask. Ill speak to him this evening. He is starting to break the car tomorrow. So if you are willing to wait for a day
Old Jan 3, 2009 | 05:34 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yep, thanks
Old Jan 3, 2009 | 07:34 PM
Mr.T's Avatar
Mr.T
KMS management spec list
KMS Management ECU MP25(M)/MA25(M)
- Complete engine management system up to 10 cylinders
- Lambda-control self-learning with standard or wideband sensors
- Boost control (gear independent)
- Launch control / Pitlane limiter (variable)
- Idle control
- Powershift (separate delay and cut-off time for each gear)
- A.L.S. (variable)
- Engine diagnostics
- 3 auxiliary outputs ( Shiftlight, water-injection, cooling fan, etc.)
- RPM limiter
- 2 engine load sensors
- Analogue input ( 2nd lambda, gearbox position, G-force sensor, EGT, etc.)
KMS UEGO Display set
KMS UEGO Display Controller is not only to be used as an controller for the KMS management system but also to be used as an display for Lambda value.
- Lambda range 0.65-1.35 or AF ratio 9.5-19.8
- Analoge output for management system
- Serial and CAN com port for displaying boostpressure,
air intake temp. etc.
- Graphic display 128x64
- Sample rate 2000/sec.
- Included Bosch LSU4.9 wideband lambda sensor
Old Jan 3, 2009 | 07:36 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Does he have the KMS UEGO kit for sale?
Old Jan 3, 2009 | 07:39 PM
Mr.T's Avatar
Mr.T
Didnt think he will sell the UEGO kit separate. BUt i will ask.
Old Jan 3, 2009 | 07:52 PM
rst in breaking's Avatar
rst in breaking
could you get better pics of the exhaust manifold please? thank you
Old Jan 3, 2009 | 08:01 PM
Mr.T's Avatar
Mr.T
THis ok for you?
Old Jan 7, 2009 | 04:45 PM
fez2i16v's Avatar
fez2i16v
is the suspension for sale?
Old Jan 7, 2009 | 05:41 PM
Mr.T's Avatar
Mr.T
It is but i think its cheaper to get a set in the UK. As sending the springs etc from holland to the UK wont be cheap
Old Jan 7, 2009 | 05:46 PM
andy130's Avatar
andy130
brace front how much
Old Jan 7, 2009 | 05:49 PM
Mr.T's Avatar
Mr.T
50 ex PP please
Old Jan 13, 2009 | 01:24 AM
scoobypete's Avatar
scoobypete
is the roll cage for sale??????
Old Jan 13, 2009 | 02:30 AM
Mr.T's Avatar
Mr.T
Sorry allready sold
Old Jan 15, 2009 | 11:39 PM
pjdj1989's Avatar
pjdj1989
steering wheel?
Old Jan 16, 2009 | 03:53 AM
Mr.T's Avatar
Mr.T
Originally Posted by pjdj1989
steering wheel?
Price is in the list above. Its still for sale
chowfornow
14
Jan 5, 2019 09:01 PM
mondeomark
Sep 28, 2015 06:28 AM
