Perspex glass
Old Jan 3, 2009 | 10:23 AM
blueskies85's Avatar
blueskies85
Default Perspex glass
Ok so the mission for getting my s2 on a diet continues, stripped out interior and looking at perspex from these guys http://www.plastics4performance.com/...D=678&P_ID=486
thats the kit im looking at too, just wondering whether its worth it and how much weight i can actually save!
Do the front windows have the hole in the side to slide open or are they standard up and down units?
Old Jan 3, 2009 | 10:25 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You want polycarbonate over acrylic really. It's safer.
blueskies85
yeah thats what the kits im looking at are mate, polycarbonate
Old Jan 3, 2009 | 10:44 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Oh, you said Perspex. Perspex is a brand name of Acrylic. Lexan is a brand name of Polycarbonate. I guess I should have clicked on the link to find out the truth
Old Jan 3, 2009 | 10:45 AM
zvhturbo29rs's Avatar
zvhturbo29rs
Default weight
i was wondering the same thing mate.hopefully someone will reply.
blueskies85
lol no worries! Any idea on how much weight the kits save?
Old Jan 3, 2009 | 11:21 AM
gus's Avatar
gus
i never weighed mine, should have
you will save a LOT 4 sides and a back probabvly weigh the same as a standard rear screen
the sliders in the front, they are a option
i wouldnt use polycarbonate as a normal window (in the winder) it will scratch big time
Old Jan 3, 2009 | 08:57 PM
Kevin_Mc's Avatar
Kevin_Mc
as Gus said, you'll save a shit load of weight - have you ever tried to carry a tailgate with glass then without the glass?!
it weighs very very little without i can assure you
Also i wouldn't have the perspex/poly windows going up and down, they'll be scratched beyond belief after 5 or so up and down trips
Old Jan 4, 2009 | 09:42 AM
Badman38's Avatar
Badman38
so what would you use instead.
thanks
sean
Old Jan 4, 2009 | 10:08 AM
gus's Avatar
gus
if you wanna keep the winder mechanism i would keep the glass in the front doors
or you could use the sliders (im not a fan of these)
Old Jan 4, 2009 | 10:25 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You don't typically keep winders when you go plastic.. that's what the little sliding panel is for on the side!
Old Jan 4, 2009 | 12:31 PM
Kevin_Mc's Avatar
Kevin_Mc
i'd agree with that, most if not all plastic/poly windows don't wind down, that's what the slider is for and even then that gets scratched to buggery most of the time
Old Jan 4, 2009 | 12:36 PM
theburns1's Avatar
theburns1
cannock is a race track
i was think of gettin some poly windows for mine, and was thinking of a see though film, or a light tint on them to stop them from scatching. do you think it would help?
Old Jan 4, 2009 | 01:41 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
If you want the windows to wind up and down then you better check withthe manufacturers that the lexan piece is exactly the same size as the OE glass, some are ony half the size and not designed to use the original mechanism....
I can't see why tinting it would be a problem, would stop it scratching for sure.
Dan
Old Jan 4, 2009 | 06:26 PM
Kevin_Mc's Avatar
Kevin_Mc
you'll struggle to get them tinted with normal tinting film, i know a guy who runs a window tinting company and he told me that the plastic expands at a different rate to the tinting film, it is designed to be used with glas which expands at a very similar rate to glass
i don't know if you can buy a special film for it but mainstream stuff will look poo
Old Jan 5, 2009 | 12:03 AM
ram's Avatar
ram
Has a large member
i plan on getting polycarb rear quarters and rear window.
but i want to keep my rear quarters opening ones, not sealed. seeing as there is a rubber seal all the way round i dont see why these should rattle etc.?
Old Jan 6, 2009 | 07:01 PM
blueskies85
didnt know my back windows opened
Old Jan 7, 2009 | 03:46 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
If they're standard they don't
Old Jan 7, 2009 | 10:47 PM
ram's Avatar
ram
Has a large member
as said above, yours dont. unless u got s1 windows. i was on about my fez
Old Jan 8, 2009 | 09:42 PM
Kevin_Mc's Avatar
Kevin_Mc
they should be fine as long as the seal's there yeah
Old Jan 8, 2009 | 10:33 PM
Smartdj.'s Avatar
Smartdj.
this is probaly the most stupid question but how do u fit them? glue or new rubbers?
Old Jan 9, 2009 | 12:21 PM
Kevin_Mc's Avatar
Kevin_Mc
i would just cut them to the same shape and size of the old glass and put them in the rubbers - some people probably bond them to stop them coming out if they flex, can't say i've ever seen them come out on other cars before.
Old Jan 9, 2009 | 12:55 PM
gus's Avatar
gus
i have just used the same rubbers again on mine
Old Jan 9, 2009 | 01:17 PM
Smartdj.'s Avatar
Smartdj.
how did you get your old windows out without messing the old rubbers up
Old Jan 9, 2009 | 03:49 PM
dangerousbrian's Avatar
dangerousbrian
how thick is the plastic getting used on the windows? surely if they are the same thickness as the glass then they will rattle anyway..there will be toomuch flex and they would move with the vacuum every time you close the door..then if the perspex is thicker is any weight actually saved?
Old Jan 9, 2009 | 04:17 PM
gus's Avatar
gus
push
Old Oct 17, 2009 | 04:42 PM
Red_bull's Avatar
Red_bull
Has anybody who bought them, sinds this thread has no reaction, and knows how much kg you safe with these windows?
Did you guys brought them from plastics4performance? Are the a nice fit? What are the differences between the set of 150 pound and the one of 300 pound?
Old Oct 17, 2009 | 05:50 PM
jonny s2's Avatar
jonny s2
im getting these for mine soon and would like to know if the bronze tint is better in terms of scratch resistant compared to the clear ones
Old Oct 18, 2009 | 12:29 PM
Micky's Avatar
Micky
I weighed the glass rear quarters and the persplex/lexan rear quarters.The differance was 1 kg in favour of the persplex.Not a great amount.I didnt weigh the door glass,so dont know a figure.As well as the scratching,have you lads also considered how easier it is to break into a car with perspex windows???Regards,Micky
Old Oct 18, 2009 | 12:48 PM
Red_bull's Avatar
Red_bull
i don't think people fit them on non track car or am i wrong?
mk1turboestate
Dec 2, 2015 08:31 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sunburstred
Sep 9, 2015 11:24 PM
