project evo vii 550bhp update today
impreza wrx sti version 8
i started with my evo vii and was just after a little more power so i had it remapped then i got the bug properly so i took out the engine going 2.3 550ish bhp fitting a ix alluminium roof mr style here are some pics from the engine work right to removing the roof
4g64 crank
wiseco pistons
manley rods
polished head
1mm oversize valves
ti retainers
twin plate
285 cams
verniers
30/76 turbo
1000cc injectors
balancer shaft eliminator
etc
from
to
stripped ready for machining
new rods and pistons
9 rear end
and my home made gauge holder:smthumbup
and now for some real horsepower lol
a trial fit ofthe new panel
4g64 crank
wiseco pistons
manley rods
polished head
1mm oversize valves
ti retainers
twin plate
285 cams
verniers
30/76 turbo
1000cc injectors
etc
from
to
9 rear end
Did u pull the roff off just to get a non sunroof on there?
Not tempted with a carbon one?
Forget that, i'm obvioulsy blind...its an ally one.
Nice way to save weight and bin off the sun roof.
Did you weigh the old and the new just to compare? Good saving even a couple kgs at the furthest point away from the centre of gravity.
Engine sounds like a wee monster too
Nice one Gus
Twin pumper is here with your name on it
You forgot to tell the full story about the MR roof!
Ross offered it you for 400 odd quid.....you declined his offer so Ross sticks it on fleabay and you get it for 31 nicker
so thats a bonus
now then gus i hope alls well i see you still like fooking about with cars lol. looks a nice mota mate and i'm glad to see it's getting some work done to improve the performance due to the extreem wieght of the driver. only joking chap nice to see you still do a bit mate. looks like you'v got a bit to do bt i'm sure it will be worth it pal. anyway it's a big leap forward to the old fords pal a nice modern car with heeps of potenial to be fast and reliable, keep up the good work chap i will be in touch soon fella happy new year and all that bullshite mrb
Now that's fookin funny, bet you enjoyed picking the roof up!
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Gus, as per our text conversation last night - give Turbo Dynamics a bell and ask them if they can do you an Evo 9 GT compressor housing with GT30 compressor wheel, roller bearing core and GT30 turbine wheel in an external wastegate twin scroll back end
It's essentially a FP Red but i seem ro recall you can only get the Red on an internal gate setup
.Mark
< one of those for me
I'd like to see how one of the FP Reds behaves on a stroker engine - on the digging i did on it last night i was led to believe it was GT30 based wheels...
I can only find it in an internally gated setup and i know Gus wants to run external...
Have you tried the FP Red yet Mark?
I stand corrected!
Mark
(( JeroentjeRS ))
How do you name the little thing you have in your hand?
[/quote]
Its a (( Internal bore micrometer ))
[/quote]Its a (( Internal bore micrometer ))
Gus, that GT3076 i used earlier in the year on a 2.0 with the smaller exhaust housing did 517bhp with 470lb/ft - i'm sure the stroker motor will prefer the bigger exhaust housing
Should make for a fast motor
not like 2 jobs are enough
