Painting my spoiler help !
Old Dec 28, 2008 | 09:47 PM
xr3iAlex's Avatar
xr3iAlex
XR3i ALEX
Default Painting my spoiler help !
hay there i have got a 90 spec xr3i spoiler that someone has laqured. i want to paint it. some people say you cant paint the rubber spoilers ? i so how do you do it ?
Old Dec 28, 2008 | 09:51 PM
mechanic28's Avatar
mechanic28
cann ot remember whats its called but u need special paint that will flex with the rubber part of ya spoiler
Old Dec 28, 2008 | 09:55 PM
matts1's Avatar
matts1
pm jacko mate, he seems a sound chap and does it for a living so will give you the info you need to sort it.
Matt
Old Dec 29, 2008 | 06:54 AM
The spoilers are made of PU RIM, a type of polyeurothane(sp) they can be sprayed no probs using a plasticiser, a flex agent in the paint.
One problem that can occur is that when they are made in moulds, the moulds are coated with silicone anti stick to ease getting the finished spoiler out, this can come through after a while(years) and so need doing every so often, years though not months.
Old Dec 29, 2008 | 02:16 PM
jacko's Avatar
jacko
before you paint it put it some where worm for a week let it get any thing inside out
then whipe it off with a good cleaner/pannel whipe
then prime with a 2k primer with flexible addative added to primer then after its dry (remember to let it air dry dont force it with heat or it will pop) wet flat this with 800 grade paper then paint with the same addative in the paint as the primer
Old Dec 29, 2008 | 02:18 PM
xr3iAlex's Avatar
xr3iAlex
XR3i ALEX
Cheers chaps,someone said they will do a swap for a rs turbo one what you recken ?
Old Dec 29, 2008 | 02:19 PM
jacko's Avatar
jacko
if the paint on the turbo one has cracks on it do your own mate more hastle than its worth
Old Dec 29, 2008 | 02:22 PM
xr3iAlex's Avatar
xr3iAlex
XR3i ALEX
rite i will remember that whats my 90 spec spoiler worth ?
Old Dec 30, 2008 | 11:29 PM
xr3iAlex's Avatar
xr3iAlex
XR3i ALEX
i am going to paint it with cans mate can i still get that addative ? alos someone has sprayed clear laqure on my spoiler what should i do ?
Old Apr 9, 2009 | 08:40 PM
slimwynn's Avatar
slimwynn
can u recommend a flexible addative make ??? cheers
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
