cosworth 2wd frond brakes????
Old Dec 28, 2008 | 09:45 PM
cossievy97's Avatar
cossievy97
Default cosworth 2wd frond brakes????
my car is an 88 saph cosie 2wd and i was wondering if its posible to use focus rs 324x28 frond discs with my std 2wd calibers and mintex pads.as far as i know my car has 283x24 discs so i was thinking of using spacer plates to widen the calibers from 24 to 28 mm and adaptor plates to move them far out.as i am aware of the focus uses brembo 4-pots and 2wd use 4-pots.for the rear i am thinking of 4x4 calibers and discs.is the frond set ub posible?will it work?
Old Dec 28, 2008 | 10:44 PM
JHS's Avatar
JHS
Originally Posted by cossievy97
will it work?
It might do if you post your question in the right place...
Old Dec 29, 2008 | 06:25 AM
Yes it will work, reyland sell the brackets/spacers to do this.
original
Apr 28, 2026 05:20 PM
bigluke200
14
Sep 2, 2015 10:35 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
