ECU's compared
Old Dec 28, 2008 | 02:05 PM
BRAMMER's Avatar
BRAMMER
Default ECU's compared
Tried searching but nothing specific comes up.
What is the differences and advantage between P8 and L8??
Cheers.
Old Dec 28, 2008 | 02:16 PM
Dave Henshall's Avatar
Dave Henshall
main differnece is more memory which allowed some extra features:
in ford form they didnt offer any advantage other than the P8 offered closed loop boost control with overboost facility.
i've been told that the injector drivers are superior in the P8 and the same car with just a swap of the ecu hardware form L8 to P8 will produce slightly more power
the P8 has a Limp mode in which boost and revs are limmited if it detects a faulty input sensor. a lot of poeple slate the P8 for this saying it's unreliable - BUT its actually highlighting faults that a L8 will run with and in turn COULD end in catastrophic failure.
the P8 hardware can also run coilpack/wasted spark althoug the ford software doesnt utilise it.
with revised software from the likes of RP labs, you can have all the facilities of the P8 on L8 now, and be able to live map it - which IIRC there is nobody in the UK who has the setup to live map the P8.
Old Dec 28, 2008 | 02:20 PM
costina's Avatar
costina
Live long and prosper!!
Not a great deal cos Stu can do much more with the L8 now the P8 is a quicker ecu just like a computer but i've been told its prone to failure
only advantages is newer,quicker,cheaper for coilpack conversion
Disadvantages,Prone to failure no adjustment for co so u need to run lambda,chips are more expensive
other than that i see no ral difference that u would notice driving your car
Paul
Old Dec 28, 2008 | 02:36 PM
BRAMMER's Avatar
BRAMMER
Great advise above lads cheers
Old Dec 28, 2008 | 02:38 PM
mechanic28's Avatar
mechanic28
think stu/tony etc can live map the P8 but it is difficult too do
Old Dec 28, 2008 | 02:52 PM
costina's Avatar
costina
To be honest unless you already have a P8 then stick to a L8
Paul
Old Dec 28, 2008 | 03:00 PM
markk's Avatar
markk
Disadvantages, no adjustment for co so u need to run lambda,
Paul
why would you need to run a lambda probe ? i never did in many years of rallying with a P8 with ALS, dual map, coil pack, and what a surprise no failures, P8 is a great ecu, as long as your tuner/mapper knows it inside out and can work with its functions.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
griffo69
Oct 4, 2015 11:58 AM
The Enigma
Sep 29, 2015 10:31 AM
DixieTheKid
Sep 14, 2015 09:04 PM
