brake pipe snapped!
Old Dec 26, 2008 | 02:04 PM
blueskies85's Avatar
blueskies85
Default brake pipe snapped!
ok so one of the last teething problems with the engine change now... the bastard brake pipe mount snapped!
Its the pipe that comes out of the reservoir, the most forward one and goes down into the master cylinder i think it is called.
I was thinking of putting a plastic pipe inside it and then mounting the pipe to it.. i dont really know if that'll be safe enough though.. it must have happened to someone else. Anyone got any suggestions?
Old Dec 26, 2008 | 02:08 PM
sm's Avatar
sm
get a new one made, wont cost much and when it comes to brakes dont bodge anything, do it right they may save your life one day
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
buy another one mate it aint worth messing around with bodging up breaks
Old Dec 26, 2008 | 02:11 PM
blueskies85
yeah thats what i was thinking
Old Dec 26, 2008 | 03:34 PM
blueskies85
ok im loosing light now but i think ill be able to remove the rubber bungs and take the snapped pipe out and then put the good pipe back on.. Its not gash it will just mean the pipe is about 1 cm shorter, i have checked and there is enough play in the pipe.
Does anyone know what the items are called? They are lower than the reservoir and there is 2 of them, there are some pipes going into them from the top and bottom and there is an arrow on one of them. There is also some pipes with springs around them. I think it may be something to do with abs and if i can remove them as abs is a pain in the arse that will be cool... ill do some more research to be honest lol
Old Dec 26, 2008 | 11:11 PM
rst in breaking's Avatar
rst in breaking
if you men the abs pipes from the reservoir i had these blanked off as the stumps into the master was different legnths on non abs models, but i wasnt using abs with my set up, if keeping abs buy a new one along with new seals to be safe
Old Dec 26, 2008 | 11:13 PM
blueskies85
yer mate thanks for the advice! Im going to bin them tomorrow and completely remove the abs.... just out of interest did you crash the bmw in you sig? If so where and was everyone ok? Looks savage!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
