Is this a 3 door hub?
OK. Good! The thing that had me questioning was the ABS sensor plug thing. I thought 3 doors had no ABS. Am I wrong? Or is it not an ABS sensor plug?
Anyway, I'm fitting them.
Thanks.
Charlie
Thanks.
Charlie
3 door cossie had abs, the easy and quick way to tell if any hub is cossie is to look at the part of the hun that holds the strut then bends to meet the bearing part, if it NOT sculpted out it is cossie, if it is scuplted out it is a std one, there's a very marked difference.
Thanks all,
Charlie
chowfornow
14
Jan 5, 2019 09:01 PM
