cheap n cheerfull
Old Dec 18, 2008 | 03:42 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
Default cheap n cheerfull
ello 2 all.. im taking the engine out of a 1.8 zetec 94 escort and puttin into a 1.6 mfi 88 escort(xr3i).. im tryin 2 do this as cheaply as poss.. iv no probs with it but 2 wire it up is a real head scratcher.. any help with this would be appreciated.. thanks..
Old Dec 20, 2008 | 11:39 AM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
add good dig round inernet.. found this, usher racing, they claim that if use a early esc wiring and a pinto carburettor on a made up manifold then ur good 2 go.. don,t get much cheaper than that.. sounds 2 easy tho,, any 1 tried that?? or am i best off gettin megasquirt??
Old Jan 2, 2009 | 11:02 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
your help on this lads has been overwhelming.. ive decided 2 tryin keep the 1.8 zetec loom.. buy just cutin off what i dont need.. like lights/heaterswitches etc.. so far so good.. decided 2 keep the PATS system.. by fittin the key senser and barrel 2 the XR3.. still tryin 2 find a way 2 remove the fuse box from the zetec loom.. theres still a few wires runnin into it.. wen i remove them she wont start.. i know the fuel pump relay is on it i can bypass that easy enough.. what else do i need off it?? or am i on me tod with dis 1. ill try nget some pics up soon..
Old Jan 3, 2009 | 12:00 AM
ram's Avatar
ram
Has a large member
you'll get help with this if you post it up in the tech room
Old Jan 3, 2009 | 12:08 AM
blk-Mk5-zs's Avatar
blk-Mk5-zs
zetec on a carb with esc is simple.
the esc only needs a live earth and rev counter to one half of the coil (will read half but you get what you pay for)
Old Jan 3, 2009 | 12:18 AM
leejones09's Avatar
leejones09
hi mate let us know how you get on,would of been alot easier for you if you started with efi but good look mate,got no plans for this but very intrested post sum pics and let us know what you had to change chop or adjust
Old Jan 11, 2009 | 04:23 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
theres life.. cheers lads.. still tippin away at this.. engines in, zetec looms in but not fully connected..alternator done.. had 2 make up and weld a bracket on accelerator pedel 2 accept zetec cable.. stuck on few things tho... which pipe is fuel in???? and theres a black box on the drivers side outside the inner wing>(somiin 2 do with breathin system) theres 2 pipes on it 1 leads 2 inlet manifold the other 2 near the petrol cap .. what doe's it do?? and will i need it on the xr?? should i just block it off?? and the coolin system.. seen ure man's guide, zetec swap do it 4 200 quid.. been quite helpfull.. am i right in understandin u block the front hose on the thermostat housin??? and join the back 1 2 the bottom connection on the bulk head?? still workin on gettin pics up...
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
