Couple of q's!!
Old Dec 17, 2008 | 03:46 PM
nellrodd's Avatar
nellrodd
Default Couple of q's!!
Hi all,
Two questions here,
1) Can someone tell me if the original wheel bolts i have for my standard wheels will okay to use with my new 7 spoke softlines or do i need longer ones etc?? Been told i need different ones.
2) Ive got a FMIC with twin fans that the missus bought me, my question is where do i wire the fans up to or what do i do with them??
Many thanks
Neil
Old Dec 17, 2008 | 04:24 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
not 100% sure on the wheels,but front mount just need to wire it in the the fan loom tht wne to the the fan,make sure ur fans go the right way!
Old Dec 17, 2008 | 04:28 PM
fez016's Avatar
fez016
check if the fans are blow or suck if they suck air they have to be fitted behind the icooler if they are blow they will have to fit infront of the icooler. hope it helps
Old Dec 17, 2008 | 04:57 PM
antony215's Avatar
antony215
Escort Rs Turbo
You need different wheel bolts (Ghia ones) for the RS 7 spokes you can get them from speedshack or they do them on ebay
Old Dec 18, 2008 | 12:24 PM
nellrodd's Avatar
nellrodd
Thanks!! Yeah thats what i was told for the wheel bolts. Will get that sorted out!!
The FMIC has 2 blower fans, so they just need to be wired in the fan loom????
Neil
Old Dec 18, 2008 | 12:45 PM
antony215's Avatar
antony215
Escort Rs Turbo
As said above wire them into the fan loom or put them on a separate switch so you can control when you want them on.
Old Dec 19, 2008 | 02:13 PM
nellrodd's Avatar
nellrodd
Thanks for the replys!!
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
