Hydraulic Clutch.....
Anyone done a Hydraulic Clutch conversion on an RST? I'm using an MTX gearbox now and am interested in hearing about Hydraulic Clutch conversions either with any gearbox......
The only disadvantage of this mod is loosing the right hand heater vent as master cylinder gets in the way of one of the duct so it has to be removed.
It took him ages to do and get the right pedal hight and also tried different pedal ratio's but it does work well
done same as above a use 6 speed box now with internal hyd release bearing,i removed complete pedal box assembly and used similar looking slave cylinder as shown above,not a bad job,just bit time consuming until u get pedal 100%.
Bodybuilding
From: Cannot be identified by the information given.
how come you changed over did you have any problems with the mtx75 box ?
no never had 1 bit trouble with mtx75 with atb in it,keeping hold of it until a see results of 6 speed.
no photos as such yet al get some done and posted up.
if you fancy a ST 6speed box i have a mint 1 from a 225 focus on only 5k miles (local too)
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
