which battery
Old Dec 15, 2008 | 09:37 PM
cossiewill.'s Avatar
cossiewill.
Brit With A Tan
Default which battery
So i am looking to upgrade the battery in my 4x4 saph and was wondering what your lot recommend.
I am gonna be installing a semi hefty sound system in her as well so it need to be a little more beefier then standard.
Ww
Old Dec 16, 2008 | 07:40 AM
Doesn't matter what size battery you have if you are drawing too much it will still flatten.
Are you using lots of stereo in car parks etc with the engine off, or will it be driving along all the time ?
There are loads of batteries to choose from these days, lots of different types as well, and also a new EN rating that makes comparison difficult with SAE rated batteries.
The best performance wise is AGM/GEL but anywhere from £130- £190, lesser batteries such as lead/calcium, calcium/calcium etc are available starting at around £60 for a decent one.
On sierras I fit the heavy duty diesel battery as it is about the biggest that will go in, unless you are happy to change connectors, as ford flat terminals are seriously on the way out now, even ford have been using round post since 95/96.
Old Dec 16, 2008 | 07:29 PM
cossiewill.
Brit With A Tan
Everning Tab
Do you have any particular models that you could point me at?
Ww
Old Dec 17, 2008 | 06:37 AM
I'll look in me books today for you, a lot though depends how deep your pockets are.
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
