Inspiration for Zetec upgrade
Old Dec 15, 2008 | 09:34 PM
westy7's Avatar
westy7
St170 now 99% Done
Default Inspiration for Zetec upgrade
Hi guys please be gentle newby
currently have a Westfield powered by a standard 130ps 2L zetec
add twin 45 webbers and alpha ecu this now pushes out 168 bhp
But its not enough it never is,
has anyone dropped a ST170 head on the zetec if so what benefits pitfalls would i come across
is it an easy mod
will the zetec cams and stuff fit on the st head
what sort of power am i looking at if my ecu can run the vvt
Westy7
Old Dec 15, 2008 | 09:50 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I doubt your twin 45's would be big enough to benefit from an ST170 head..
Old Dec 15, 2008 | 10:08 PM
bristol_fez's Avatar
bristol_fez
i am pretty sure if your zetec engine is a silver top then the st170 head wont go on it anyway
Old Dec 15, 2008 | 10:38 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It will.. you just need to suss out a new cam belt tensioner.
Old Dec 15, 2008 | 10:52 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
how do you go about it?
fancyed it in the futcher
Old Dec 16, 2008 | 06:01 AM
Johnny Knoxville's Avatar
Johnny Knoxville
Ditch the silver top water pump and fit a electrical one so it removes the water pump pulley then you can fit the ST head
Old Dec 16, 2008 | 07:04 AM
bristol_fez
my mistake, i thought that some of the water and oil ways did not match from the silver top block to a black top head. Could you explain more on what is needed to make it fit then?
Old Dec 16, 2008 | 04:56 PM
westy7's Avatar
westy7
St170 now 99% Done
Thanks for the replies so far.........
please keem em coming , im soaking it all up like a sponge
Old Dec 17, 2008 | 03:25 PM
SiZT's Avatar
SiZT
why would the water pump pulley interfere (sp?) with the cambelt tensioner?
Old Dec 17, 2008 | 05:01 PM
Johnny Knoxville
Not the tensioner but the cambelt itself
Look at a S1/2 cambelt setup and a S3/ST170 one and you will see for yourself
Old Dec 17, 2008 | 05:30 PM
wide ka's Avatar
wide ka
why not change the cams, and do some work on the head, should see over 200bhp then
Old Dec 17, 2008 | 05:40 PM
rst in breaking's Avatar
rst in breaking
have you considered turbo'ing it?
Old Dec 17, 2008 | 10:17 PM
westy7's Avatar
westy7
St170 now 99% Done
cams and headwork not cheap then rolling road retune
gotta be looking at over Ł1200 -Ł1500
trying to gain poweron a budget aint easy
can get a full st170 engine for Ł350 so thought it would be alot easier and cheaper to get a few more horses
if im barking up the wrong tree please tell me
sounds like i need your help
anyone else got any ideas on more power for the zetec ,which cams to fit, with or without headwork.
anythink else obvious that i missed
cheers
and a happy new year to you all
Rob
Old Dec 31, 2008 | 12:46 PM
westy7's Avatar
westy7
St170 now 99% Done
bump
Happy New Year to one and all
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sp3no
Sep 27, 2015 07:23 PM
