rs door pins query?
orion=mini saff
2 ways,take the dash out and slightly moved the hinges,or the slighty cruder way,open the door and pull it up a bit if ya feeling strong!signs people been hanging off it!
no need to take the dash out on a mk3 (series one) just remove the speaker cover in the footwell and you can get to the bottom bolts piece a cake,and if you remove the plastic pocket to the right of the dash, "under the switches" you can get to the bolts for the top hinge piece of cake also.
chowfornow
14
Jan 5, 2019 09:01 PM
muz
Sep 30, 2015 08:29 AM
Vacuman
Sep 22, 2015 12:09 PM
will have a right gander tonight and see if i can see anything.cheers peeps.
