Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Escort gti fuel gauge
Old Dec 14, 2008 | 10:09 PM
rsdan123's Avatar
rsdan123
Default Escort gti fuel gauge
hi every one i have just brought an escort gti for a run around cause the turbo blow up again! the fuel gauge says its empty all the time what could this be other then the dials or pump/sender. is there any way of teating the dial or sender or would it just be a case of buying a new one?
cheers for any help
Danny
Old Dec 16, 2008 | 07:27 AM
Most likely a broken/coroded wire, if you can figure which is the sender wire just earth it, the gauge will then read max, then find the break whatever, most likely at tank end.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
