Strut brace best way to fit ??
Old Dec 14, 2008 | 05:17 PM
SO COSSIE's Avatar
SO COSSIE
Default Strut brace best way to fit ??
Should the strut brace be fitted when the car is on all four wheels or when the cars is jacked up??
Old Dec 14, 2008 | 07:45 PM
fordrallycar's Avatar
fordrallycar
No mate just the front thats how i did mine & then had the tracking cheked
Old Dec 14, 2008 | 08:01 PM
Kelv's Avatar
Kelv
Almost there!
Paul, have you just answered a different question mate
Old Dec 14, 2008 | 08:23 PM
Aaroncast's Avatar
Aaroncast
Default Should the strut brace be fitted when the car is on all four wheels or when the cars
ARE YOU FOR REAL????????????
--------DOES NOT MATTER-LOL
WHY WOULD YOU WANT TO JACK IT UP TO FIT A STRUT BRACE-
OR EVEN GET IT TRACKED AFTER!!!!!!!!!!!---LOL
*edited - BE NICE! *
Old Dec 14, 2008 | 08:43 PM
Moonstone Mart's Avatar
Moonstone Mart
Aaron, sounds like a good question to me, im would think he is thinking that if the car is on its wheels the forces would be pushing the inner wings/strut tops would be pushing in slightly more than if the weight was taken off the inner wings by jacking it up.
No need for your post id say
Mart.
Old Dec 14, 2008 | 09:04 PM
xr4x4rs's Avatar
xr4x4rs
if the engine is in it shouldnt matter
but when i did the sierra with no engine in and fitted the brace, it fitted lovely, but once the engine was fitted i had to line the strut brace up with the holes as with the weight of the engine in it moved the struts slightly
Old Dec 14, 2008 | 10:42 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hope your joking pal because your 100% WRONG. To fit it properly often needs the suspension uprights removing and on some the fitment will alter the suspensions alignment so requires 4 wheek alignment afterwards ideally.
Old Dec 15, 2008 | 08:02 AM
AlexD's Avatar
AlexD
Post Miester !
I would say, drill the holes with the car sat on the floor, then jack up to fit.
If fitting a Front and Back one deffo worth gettin the tracking checked imo.
Old Dec 15, 2008 | 06:49 PM
SO COSSIE's Avatar
SO COSSIE
Just the frount one at the mo but like tou say when jacked up the struts move apart ie wider gap not a lot but still like to check and get it right.
So were saying jacked up retracked
Old Dec 16, 2008 | 01:13 AM
c0ss1e9i6's Avatar
c0ss1e9i6
Franco
A quick question to ease my thick skull!
I fitted my rear strut brace a while ago and this thread had me pondering!
If the back one goes on easily when the car is sat on its wheels and it is just a solid bar, what difference would jacking it up make?
I fully understand that taking the load off wheels could potentially move the turrets in which case, if it moves them that much, surely the brace wouldn't fit!
(SENSIBLE explanations please!)
bigluke200
14
Sep 2, 2015 10:35 PM
FlashRS
13
Aug 31, 2015 06:02 PM
155lee
Aug 14, 2015 11:21 AM
RIB1122
Aug 12, 2015 08:49 PM
track.focus'd
Aug 12, 2015 05:53 PM
