turbo with throttle bodies
Old Dec 14, 2008 | 11:33 AM
McGoo 69's Avatar
McGoo 69
Default turbo with throttle bodies
hi
i am toying on the idea of using bike throttle bodys with a pleminum casing around them so i can use them with a turbo on my focus rs engine
i know it has been done before but im wondering if theres anything extra i need to know or is it simply making a case around the throttle bodies to connect up the pipe work?
cheers
Old Dec 14, 2008 | 11:59 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You'll need suitable management and mapping... a costly exercise, trust me!!
Also it's quite likely that throttle bodies designed for n/a use will not seal properly under boost.
Old Dec 14, 2008 | 12:05 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Bike carbs are designed to run under vacum, if you try putting a bar of boost up their arse they might have sealing issues. I'd try to do a bit of a drop test if you can on one of the TBs....seal it all up and fill with a measure of gas (welding gas works well) say at like 3 bar and see if it drops much, or if it pushes out any internal seals etc...
If it holds the pressure then there's no reason why not to use them.
Dan
Old Dec 14, 2008 | 12:33 PM
McGoo 69's Avatar
McGoo 69
thanks for that lads good job i checked it out
was thinking it would be fairly straight forward.
ah well back to the drawing board haha
muffster
13
Sep 3, 2015 09:40 PM
Russ Hill
Aug 31, 2015 06:44 PM
Cosnada
Aug 27, 2015 09:15 AM
Dicko&Vacant
Aug 21, 2015 05:59 PM
M K
Aug 12, 2015 06:57 PM
